Ga door naar hoofdinhoud
Canon PIXMA iP3600 AC Adapter Replacement
    1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: stap 1, afbeelding 1 van 2 Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: stap 1, afbeelding 2 van 2
      • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
      • Remove power cord by disconnecting it from the AC Adapter.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PIXMA iP3600 AC Adapter Replacement: stap 2, afbeelding 1 van 2 Canon PIXMA iP3600 AC Adapter Replacement: stap 2, afbeelding 2 van 2
      • Pinch upper and lower prongs, moving them away from the AC adapter.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PIXMA iP3600 AC Adapter Replacement: stap 3, afbeelding 1 van 2 Canon PIXMA iP3600 AC Adapter Replacement: stap 3, afbeelding 2 van 2
      • The AC adapter will now be loose, and able to come away from the printer.
      • Grasp the AC adapter and pull it toward you to remove it.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PIXMA iP3600 AC Adapter Replacement: stap 4, afbeelding 1 van 1
      • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PIXMA iP3600 AC Adapter Replacement: stap 5, afbeelding 1 van 3 Canon PIXMA iP3600 AC Adapter Replacement: stap 5, afbeelding 2 van 3 Canon PIXMA iP3600 AC Adapter Replacement: stap 5, afbeelding 3 van 3
      • Grasp the white connector head that is attached to the end of the blue cord.
      • Disconnect the white connector head by gently pulling it away from the AC adapter.
      • You have successfully removed the AC adapter.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Caitlyn
1.223 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Leahy Fall 2014 Lid van USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Leden
8 handleidingen geschreven
3Gids Commentaar
Does anybody know the pin-out for these power supplies?
James Rudee - Antwoord Deel
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - Antwoord Deel
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 56
Altijd: 5,945
