Inleiding
If you find that your scanner light does not seem to be moving, then your scanner belt could be the problem. Your scanner belt could be damaged or worn. This guide will help you to replace your scanner belt.
Wat je nodig hebt
Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
Remove the black component by gently pulling it up from the black scanner belt
