Inleiding
This guide will help you to replace your scanner's glass. You may need to replace the glass if the glass has noticeable scratching, the glass is broken, or if the glass is cracked. IMPORTANT: If the glass is broken take extreme precaution in replacing the glass. Broken glass can cause damage to you and things around you. Also, if you are getting smudges when you scan in items make sure that the glass does not have any fingerprints, smudges, or dust on it. You may need to clean your glass with glass cleaner.
Wat je nodig hebt
Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
Take out the damaged glass and fit the replacement glass to the printer according to the picture.
4 andere personen hebben deze handleiding voltooid.
