Ga door naar hoofdinhoud
Canon EOS Rebel XTi Shutter Button Replacement
Wat je nodig hebt
    1. Canon EOS Rebel XTi Shutter Button Replacement, Battery: stap 1, afbeelding 1 van 1
      • Place the camera upside down, and position it to where the back of the camera is visible.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel XTi Shutter Button Replacement: stap 2, afbeelding 1 van 1
      • Pull the orange tab to the right to release the primary battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel XTi Shutter Button Replacement: stap 3, afbeelding 1 van 1
      • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
      • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel XTi Shutter Button Replacement, Memory Card: stap 4, afbeelding 1 van 1
      • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel XTi Shutter Button Replacement: stap 5, afbeelding 1 van 1
      • Slide the memory card door in the direction of the arrow engraved on the camera.
      • Once the door has slid open to its full position, lift up on the door.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel XTi Shutter Button Replacement: stap 6, afbeelding 1 van 1
      • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
      • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel XTi Shutter Button Replacement, Back Cover: stap 7, afbeelding 1 van 1
      • Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel XTi Shutter Button Replacement: stap 8, afbeelding 1 van 2 Canon EOS Rebel XTi Shutter Button Replacement: stap 8, afbeelding 2 van 2
      • Remove the two black M3x6mm JIS #000 screws from the right side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel XTi Shutter Button Replacement: stap 9, afbeelding 1 van 1
      • Remove the two M3x5mm JIS #000 screws on the side of the camera opposite to the hand grip.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS Rebel XTi Shutter Button Replacement: stap 10, afbeelding 1 van 1
      • Remove the following screws located in the memory card slot:
      • Two M3x2mm JIS #000 screws
      Vraag FixBot
      Voeg opmerking toe
    5. Canon EOS Rebel XTi Shutter Button Replacement: stap 11, afbeelding 1 van 1
      • Gently pry off the back casing.
      • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
      • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
      • Gently pull the ribbon cable out of the connector.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel XTi Shutter Button Replacement, Front Cover: stap 12, afbeelding 1 van 1
      • Remove the following screws from the bottom of the camera:
      • Two M3x4.5mm JIS #000 screws
      • One M3x3mm JIS #000 screw
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel XTi Shutter Button Replacement: stap 13, afbeelding 1 van 1
      • Remove the following screws from the front of the camera:
      • Two M3x6mm JIS #000 screws
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel XTi Shutter Button Replacement: stap 14, afbeelding 1 van 1
      • Gently pry off the front casing.
      • There are no ribbon cables to remove for this portion of the disassembly.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: stap 15, afbeelding 1 van 3 Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: stap 15, afbeelding 2 van 3 Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: stap 15, afbeelding 3 van 3
      • Remove the following screws from around the viewfinder:
      • One 10mm JIS #00 diopter screw
      • Two M3x6mm JIS #00 screws
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel XTi Shutter Button Replacement: stap 16, afbeelding 1 van 3 Canon EOS Rebel XTi Shutter Button Replacement: stap 16, afbeelding 2 van 3 Canon EOS Rebel XTi Shutter Button Replacement: stap 16, afbeelding 3 van 3
      • Remove the following screws on each side of the camera under the strap hooks:
      • One M3x5mm JIS #00 screw
      • One M3x4.5mm JIS #00 screw
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel XTi Shutter Button Replacement: stap 17, afbeelding 1 van 1
      • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
      • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS Rebel XTi Shutter Button Replacement: stap 18, afbeelding 1 van 1
      • Unplug the yellow connector located on the top of the camera.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon EOS Rebel XTi Shutter Button Replacement: stap 19, afbeelding 1 van 1
      • Disconnect the red connector located by the USB port.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS Rebel XTi Shutter Button Replacement, Shutter Button: stap 20, afbeelding 1 van 1
      • Use a JIS #00 screwdriver to remove the two silver 4 mm screws from underneath the shutter button.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel XTi Shutter Button Replacement: stap 21, afbeelding 1 van 3 Canon EOS Rebel XTi Shutter Button Replacement: stap 21, afbeelding 2 van 3 Canon EOS Rebel XTi Shutter Button Replacement: stap 21, afbeelding 3 van 3
      • Use a JIS #00 screwdriver to remove the 3mm screws from the plate under the shutter button.
      • Place the components off to the side without removing any ribbons.
      • Be careful as ribbon cables are fragile and may rip easily.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel XTi Shutter Button Replacement: stap 22, afbeelding 1 van 1
      • Use a 1.5mm flat head bit to remove the c-clip from underneath the snapshot button by pushing against the open side of the pin.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Luis Calle
431 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-6, Eyestone Fall 2015 Lid van USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Leden
19 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 45
Altijd: 1,652
