Ga door naar hoofdinhoud
Canon EOS Rebel XTi Memory Card Replacement
Wat je nodig hebt
    1. Canon EOS Rebel XTi Memory Card Replacement, Memory Card: stap 1, afbeelding 1 van 1
      • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS Rebel XTi Memory Card Replacement: stap 2, afbeelding 1 van 1
      • Slide the memory card door in the direction of the arrow engraved on the camera.
      • Once the door has slid open to its full position, lift up on the door.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS Rebel XTi Memory Card Replacement: stap 3, afbeelding 1 van 1
      • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
      • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nicholas Abate
689 Reputatie
5 handleidingen geschreven
USF Tampa, Team 8-6, Eyestone Fall 2015 Lid van USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Leden
19 handleidingen geschreven
1Gids Commentaar
My camara wont read memory card
mcbed215 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 55
Altijd: 4,304
