Ga door naar hoofdinhoud
Canon EOS Rebel T3 Tripod Socket Replacement
Wat je nodig hebt
  1. Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: stap 1, afbeelding 1 van 3 Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: stap 1, afbeelding 2 van 3 Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: stap 1, afbeelding 3 van 3
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 Tripod Socket Replacement, Back Cover: stap 2, afbeelding 1 van 2 Canon EOS Rebel T3 Tripod Socket Replacement, Back Cover: stap 2, afbeelding 2 van 2
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 Tripod Socket Replacement: stap 3, afbeelding 1 van 2 Canon EOS Rebel T3 Tripod Socket Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 Tripod Socket Replacement: stap 4, afbeelding 1 van 3 Canon EOS Rebel T3 Tripod Socket Replacement: stap 4, afbeelding 2 van 3 Canon EOS Rebel T3 Tripod Socket Replacement: stap 4, afbeelding 3 van 3
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
  5. Canon EOS Rebel T3 Tripod Socket Replacement, Front Cover: stap 5, afbeelding 1 van 1
    • Remove the following screws on the front of the camera.
    • Two M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T3 Tripod Socket Replacement: stap 6, afbeelding 1 van 1
    • On the bottom of the camera, remove the following screws:
  7. Canon EOS Rebel T3 Tripod Socket Replacement: stap 7, afbeelding 1 van 3 Canon EOS Rebel T3 Tripod Socket Replacement: stap 7, afbeelding 2 van 3 Canon EOS Rebel T3 Tripod Socket Replacement: stap 7, afbeelding 3 van 3
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  8. Canon EOS Rebel T3 Tripod Socket Replacement, Tripod Socket: stap 8, afbeelding 1 van 1
    • On the bottom of the camera, remove the following screws from the tripod socket plate:
    • Two M2.0x3.5mm JIS #000 screws
    • Two M2.0x5.0mm Phillips #000 screws
    • Pull off the tripod socket plate.
Conclusie
Bijgevoegde documenten
Zephosk
4.561 Reputatie
29 handleidingen geschreven
LGBTQ Technicians Lid van LGBTQ Technicians
Community
34 Leden
98 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 17
