Ga door naar hoofdinhoud
Canon EOS Rebel T3 Back Cover Replacement
Wat je nodig hebt
  1. Canon EOS Rebel T3 Back Cover Replacement, I/F Terminal Cover: stap 1, afbeelding 1 van 3 Canon EOS Rebel T3 Back Cover Replacement, I/F Terminal Cover: stap 1, afbeelding 2 van 3 Canon EOS Rebel T3 Back Cover Replacement, I/F Terminal Cover: stap 1, afbeelding 3 van 3
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 Back Cover Replacement, Back Cover: stap 2, afbeelding 1 van 2 Canon EOS Rebel T3 Back Cover Replacement, Back Cover: stap 2, afbeelding 2 van 2
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 Back Cover Replacement: stap 3, afbeelding 1 van 2 Canon EOS Rebel T3 Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 Back Cover Replacement: stap 4, afbeelding 1 van 3 Canon EOS Rebel T3 Back Cover Replacement: stap 4, afbeelding 2 van 3 Canon EOS Rebel T3 Back Cover Replacement: stap 4, afbeelding 3 van 3
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
Conclusie
Bijgevoegde documenten
Zephosk
4.741 Reputatie
29 handleidingen geschreven
LGBTQ Technicians Lid van LGBTQ Technicians
Community
33 Leden
68 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 108
