Ga door naar hoofdinhoud
Canon EOS A2 Top Cover Replacement
Wat je nodig hebt
    1. Canon EOS A2 Top Cover Replacement, Battery: stap 1, afbeelding 1 van 1
      • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS A2 Top Cover Replacement: stap 2, afbeelding 1 van 1
      • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS A2 Top Cover Replacement: stap 3, afbeelding 1 van 1
      • Remove the battery from inside the battery housing and set the cover aside.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS A2 Top Cover Replacement, Front Cover: stap 4, afbeelding 1 van 1
      • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS A2 Top Cover Replacement: stap 5, afbeelding 1 van 1
      • Remove the 6.4mm screw from the inside of the flash bezel.
      • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS A2 Top Cover Replacement: stap 6, afbeelding 1 van 1
      • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS A2 Top Cover Replacement: stap 7, afbeelding 1 van 1
      • Remove the 5.6mm screws behind the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon EOS A2 Top Cover Replacement: stap 8, afbeelding 1 van 1
      • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon EOS A2 Top Cover Replacement: stap 9, afbeelding 1 van 1
      • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
      Vraag FixBot
      Voeg opmerking toe
    7. Canon EOS A2 Top Cover Replacement: stap 10, afbeelding 1 van 2 Canon EOS A2 Top Cover Replacement: stap 10, afbeelding 2 van 2
      • Starting at the flash, carefully pull the front cover away from the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS A2 Top Cover Replacement, Top Cover: stap 11, afbeelding 1 van 1
      • Remove the 4.3mm screw below the camera strap ring.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS A2 Top Cover Replacement: stap 12, afbeelding 1 van 1
      • Remove two 4.8mm screws located on both sides of the eyepiece.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS A2 Top Cover Replacement: stap 13, afbeelding 1 van 1
      • Pull the top cover up slowly.
      • A ribbon cable is attached to the bottom of the top cover and the camera. Pull up very carefully to avoid damaging this.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS A2 Top Cover Replacement: stap 14, afbeelding 1 van 1
      • Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
      • If you pull the white tabs all the way out, just insert them back in to avoid losing them.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mark
197 Reputatie
5 handleidingen geschreven
Cal Poly, Team 8-9, Regan Spring 2011 Lid van Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Leden
31 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 4,816
