Inleiding
Use this guide to replace a cracked or malfunctioning rear LCD screen on your EOS 6D.
Wat je nodig hebt
Remove the viewfinder cover by pinching the sides and sliding it upward.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Detach the two light brown ribbon wires from the back of the LCD screen by firmly gripping each with tweezers and gently pulling straight to the left.
13 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
Thank you! Thank you!! I rescued my 6D. All your steps and details were very useful.
Few points to add:
1. I think the black screw (yellow circle) from step 7 is 3 mm.
2. Lift the light brown flap that holds the ribbon cable before removing the LCD panel.
3. When you remove the LCD panel from the metal housing, you will have to pry the two strips of adhesive that is there.
4. Be careful when tightening the screws back.
Please add to setp 8: The ribbon cable is connected to the camera via a plug (the gold colored PCB has a male plug on the other side of the PCB). This plug is at the end of the spudger. You need to pull that PCB boar/plug straight up from the camera (perpendicular to the camera)
