Ga door naar hoofdinhoud
Canon EOS 5D Mark II Top Panel Replacement
Wat je nodig hebt
    1. Canon EOS 5D Mark II Top Panel Replacement, Clock Battery: stap 1, afbeelding 1 van 1
      • Lift the rubber flap covering the input/output jacks.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS 5D Mark II Top Panel Replacement: stap 2, afbeelding 1 van 1
      • Using a Phillips #000, remove the single 3.4 mm screw.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS 5D Mark II Top Panel Replacement: stap 3, afbeelding 1 van 1
      • This step will permanently erase all user settings.
      • The memory battery can now be easily slid out of place.
      • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS 5D Mark II Top Panel Replacement, Back Panel: stap 4, afbeelding 1 van 1
      • Peel back the rubber cover above the in/out ports to reveal two screw heads.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS 5D Mark II Top Panel Replacement: stap 5, afbeelding 1 van 1
      • Remove both 5.4 mm screws using a Phillips #0.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS 5D Mark II Top Panel Replacement: stap 6, afbeelding 1 van 1
      • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS 5D Mark II Top Panel Replacement: stap 7, afbeelding 1 van 1
      • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon EOS 5D Mark II Top Panel Replacement: stap 8, afbeelding 1 van 1
      • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon EOS 5D Mark II Top Panel Replacement: stap 9, afbeelding 1 van 1
      • Peel back the rubber covering next to the menu dial to access the screw.
      • Remove the single 3.4 mm screw using a Phillips #0.
      Vraag FixBot
      Voeg opmerking toe
    7. Canon EOS 5D Mark II Top Panel Replacement: stap 10, afbeelding 1 van 1
      • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
      Vraag FixBot
      Voeg opmerking toe
    8. Canon EOS 5D Mark II Top Panel Replacement: stap 11, afbeelding 1 van 1
      • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
      • The back panel is now free from the rest of the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS 5D Mark II Top Panel Replacement, Front Panel: stap 12, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using tweezers, pull out the wire attaching the front panel to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS 5D Mark II Top Panel Replacement: stap 13, afbeelding 1 van 1
      • Peel off the rubber cover on the front panel in order to access the screws underneath.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS 5D Mark II Top Panel Replacement: stap 14, afbeelding 1 van 1
      • Remove each of the 4.9 mm three screws using a Phillips #0.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS 5D Mark II Top Panel Replacement: stap 15, afbeelding 1 van 1
      • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon EOS 5D Mark II Top Panel Replacement: stap 16, afbeelding 1 van 1
      • Remove the single screw underneath where the lens would be using a Phillips #0.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon EOS 5D Mark II Top Panel Replacement: stap 17, afbeelding 1 van 3 Canon EOS 5D Mark II Top Panel Replacement: stap 17, afbeelding 2 van 3 Canon EOS 5D Mark II Top Panel Replacement: stap 17, afbeelding 3 van 3
      • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
      Vraag FixBot
      Voeg opmerking toe
    7. Canon EOS 5D Mark II Top Panel Replacement: stap 18, afbeelding 1 van 2 Canon EOS 5D Mark II Top Panel Replacement: stap 18, afbeelding 2 van 2
      • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon EOS 5D Mark II Top Panel Replacement, Top Panel: stap 19, afbeelding 1 van 1
      • Remove the single 5.9 mm screw next to the the strap loop on the same side as the shutter button.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS 5D Mark II Top Panel Replacement: stap 20, afbeelding 1 van 1
      • Remove the single 3.8 mm screw underneath the camera strap on the same side as the in/out ports.
      • If you are having problems finding this screw, note the orientation of the viewfinder in the bottom center of the photo.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS 5D Mark II Top Panel Replacement: stap 21, afbeelding 1 van 2 Canon EOS 5D Mark II Top Panel Replacement: stap 21, afbeelding 2 van 2
      • Using tweezers or your thumb, raise the clasp holding the topmost data ribbon cable in order to release it.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS 5D Mark II Top Panel Replacement: stap 22, afbeelding 1 van 1
      • The top panel is now free from the rest of the device. Lift to remove.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
15 andere personen hebben deze handleiding voltooid.
Mike Seed
3.166 Reputatie
8 handleidingen geschreven
USF Tampa, Team 1-6, Hickman Fall 2014 Lid van USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Leden
17 handleidingen geschreven
13Gids Commentaar
The strap hook on the left side of my 5d2 body got bent in a fall and I want to replace it. Do I have to go through all these steps or is there an easier way to get to it ? Thanks
Tim - Antwoord Deel
Everything it's very nice in this guide.
I just have a question?
Where do I can find the top panel to buy it?
It's seem almost impossible...
stefano masetti - Antwoord Deel
I would also like to know where a replacement top panel can be purchased from.
t1000email - Antwoord Deel
I purchased one on Ebay , (US) $100 USD
yanhao996 - Antwoord Deel
The guide is useful and quite easy to follow. Thanks
Janes - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 57
Altijd: 15,937
