Ga door naar hoofdinhoud
Canon EOS 5D Mark II Front Panel Replacement
Wat je nodig hebt
  1. Canon EOS 5D Mark II Front Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
    Vraag FixBot
    Voeg opmerking toe
  2. Canon EOS 5D Mark II Front Panel Replacement: stap 2, afbeelding 1 van 1
    • Remove both 5.4 mm screws using a Phillips #0.
    Vraag FixBot
    Voeg opmerking toe
  3. Canon EOS 5D Mark II Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
    Vraag FixBot
    Voeg opmerking toe
  4. Canon EOS 5D Mark II Front Panel Replacement: stap 4, afbeelding 1 van 1
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Canon EOS 5D Mark II Front Panel Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
    Vraag FixBot
    Voeg opmerking toe
  6. Canon EOS 5D Mark II Front Panel Replacement: stap 6, afbeelding 1 van 1
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
    Vraag FixBot
    Voeg opmerking toe
  7. Canon EOS 5D Mark II Front Panel Replacement: stap 7, afbeelding 1 van 1
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
    Vraag FixBot
    Voeg opmerking toe
  8. Canon EOS 5D Mark II Front Panel Replacement: stap 8, afbeelding 1 van 1
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
  9. Canon EOS 5D Mark II Front Panel Replacement, Front Panel: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, pull out the wire attaching the front panel to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  10. Canon EOS 5D Mark II Front Panel Replacement: stap 10, afbeelding 1 van 1
    • Peel off the rubber cover on the front panel in order to access the screws underneath.
    Vraag FixBot
    Voeg opmerking toe
  11. Canon EOS 5D Mark II Front Panel Replacement: stap 11, afbeelding 1 van 1
    • Remove each of the 4.9 mm three screws using a Phillips #0.
    Vraag FixBot
    Voeg opmerking toe
  12. Canon EOS 5D Mark II Front Panel Replacement: stap 12, afbeelding 1 van 1
    • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
    Vraag FixBot
    Voeg opmerking toe
  13. Canon EOS 5D Mark II Front Panel Replacement: stap 13, afbeelding 1 van 1
    • Remove the single screw underneath where the lens would be using a Phillips #0.
    Vraag FixBot
    Voeg opmerking toe
  14. Canon EOS 5D Mark II Front Panel Replacement: stap 14, afbeelding 1 van 3 Canon EOS 5D Mark II Front Panel Replacement: stap 14, afbeelding 2 van 3 Canon EOS 5D Mark II Front Panel Replacement: stap 14, afbeelding 3 van 3
    • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
    Vraag FixBot
    Voeg opmerking toe
  15. Canon EOS 5D Mark II Front Panel Replacement: stap 15, afbeelding 1 van 2 Canon EOS 5D Mark II Front Panel Replacement: stap 15, afbeelding 2 van 2
    • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
14 andere personen hebben deze handleiding voltooid.
Mike Seed
3.166 Reputatie
8 handleidingen geschreven
USF Tampa, Team 1-6, Hickman Fall 2014 Lid van USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Leden
17 handleidingen geschreven
1Gids Commentaar
Good write-up. I just replaced my casing using these instructions.
sebastien - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 113
Altijd: 12,619
