Ga door naar hoofdinhoud
Canon EOS 30 LCD Screen Replacement
Wat je nodig hebt
  1. Canon EOS 30 LCD Screen Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
    Vraag FixBot
    Voeg opmerking toe
  2. Canon EOS 30 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Canon EOS 30 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the 4.8 mm black screw on the left side of the camera.
    Vraag FixBot
    Voeg opmerking toe
  4. Canon EOS 30 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the front panel by lifting it away from the camera's body.
    Vraag FixBot
    Voeg opmerking toe
  5. Canon EOS 30 LCD Screen Replacement, Top Panel: stap 5, afbeelding 1 van 1
    • Slide the outer eyepiece upward to remove it.
    Vraag FixBot
    Voeg opmerking toe
  6. Canon EOS 30 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
    Vraag FixBot
    Voeg opmerking toe
  7. Canon EOS 30 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
    Vraag FixBot
    Voeg opmerking toe
  8. Canon EOS 30 LCD Screen Replacement: stap 8, afbeelding 1 van 2 Canon EOS 30 LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
    Vraag FixBot
    Voeg opmerking toe
  9. Canon EOS 30 LCD Screen Replacement, LCD Screen: stap 9, afbeelding 1 van 1
    • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
    • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
    Vraag FixBot
    Voeg opmerking toe
  10. Canon EOS 30 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Lift LCD screen out of mount.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sterling Vinson
314 Reputatie
5 handleidingen geschreven
Cal Poly, Team 8-8, Regan Spring 2011 Lid van Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Leden
22 handleidingen geschreven
2Gids Commentaar
Thank's , your tutorial nice ... gracias
fajar - Antwoord Deel
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 58
Altijd: 6,109
