Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
Remove seven 4.25 mm black screws on the bottom panel.
Remove the plastic remote control socket cap by pulling it straight out.
Slide the panel toward the bottom of the camera to remove.
Remove the single 4.8 silver screw from the control socket.
Desolder connections to replace the remote control socket.
Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward.
Remove one black screw from battery door on underside of grip.
Één andere persoon heeft deze handleiding voltooid.
