Inleiding
If you're having scanning issues as a result of a faulty sensor bar, this is where you will want to begin.
To replace the sensor bar in the Canon CanoScan N670U, you must:
- Remove the two plastic bars that hold the glass scanner bed.
- Set aside the scanner bed.
- Loosen the belt from the plastic hook.
- Remove the sensor bar for replacement.
Wat je nodig hebt
Open up your Canon CanoScan N670U to an upright position.
Één andere persoon heeft deze handleiding voltooid.
