Inleiding
Use this guide to remove, clean, and refit the dispenser drawer on a Candy washing machine. The dispenser drawer, detergent drawer, or soap drawer holds detergent and fabric conditioner, and residue can build up over time and wash onto clothes. This guide covers Candy machines with the drawer in the top-left corner of the front panel, so other models may have small differences.
Wat je nodig hebt
Stap 1 Prepare the washer
Wear rubber gloves if the drawer, cavity, or door seal has moldy residue.
Locate the dispenser drawer in the top-left corner of the front panel.
Stap 2 Remove the dispenser drawer
Pull the dispenser drawer straight out until it reaches the stop.
Lift the front of the drawer while pulling it outward to release the small retaining clips.
Stap 3 Clean the dispenser cavity
Wipe inside the empty dispenser opening with a cleaning cloth and hot, soapy water.
Focus on the visible residue inside the drawer area, not the drain hole.
Stap 4 Clean the dispenser drawer
Remove the tray from the dispenser drawer to reach the hidden areas.
Scrub the drawer and tray with hot, soapy water and an brush.
Remove washing powder residue, conditioner residue, gunge, and mold from the compartments.
Stap 5 Refit the dispenser drawer
Line up the dispenser drawer with the grooves in the opening.
Push the drawer all the way in until it is fully seated.
Stap 6 Clean the door rubber
Open the washer door with the door open button if the machine has one.
Check the rubber seal inside the door for dirt, dust, grit, debris, and blockages.
Wipe the rubber seal with a cleaning cloth and hot, soapy water.
Stap 7 Run a hot maintenance wash
Plug the washing machine back in.
Leave the drum empty.
Select the hottest wash program available, such as a 90 °C wash or Drum Clean option.
Run the cycle to flush detergent residue through the washing machine.
The dispenser drawer is clean and refitted, and the washer is ready for a clean wash. Repair didn't go as planned? Ask our Answers community for help.
