Ga door naar hoofdinhoud
CSL TM137U optical vertical mouse 26068 - disassembly
Wat je nodig hebt
  1. CSL TM137U optical vertical mouse 26068 - disassembly, Remove mouse feet: stap 1, afbeelding 1 van 2 CSL TM137U optical vertical mouse 26068 - disassembly, Remove mouse feet: stap 1, afbeelding 2 van 2
    • Only 3 of total 4 mouse feet must be removed for loosing the screws
    • Maybe heat the mouse feet to soften the adhesive for example with a hairdryer
    • Slide an opening pick under both the mouse feet and the adhesive underneath it.
    • If everything works well you can peel of the mouse feet with the adhesive and can reuse it later
  2. CSL TM137U optical vertical mouse 26068 - disassembly, Remove screws: stap 2, afbeelding 1 van 1
    • Remove the three Phillips screws holding the two halves of the mouse together.
    • Under the fourth mouse feet at the top left there is no screw.
  3. CSL TM137U optical vertical mouse 26068 - disassembly, Upper and lower part: stap 3, afbeelding 1 van 1
    • The lower part has on the left side a plastic clip.
    • Hold the lower part in place and lift the upper part of the mouse some millimeters.
    • The two parts are now separated. Only the flat ribbon calbe holds both together.
    • Lay the upper part right next to the lower part on the table.
    • A flat ribbon calbe connects the upper and the lower part. Do not separate both parts too far from each other.
  4. CSL TM137U optical vertical mouse 26068 - disassembly, flat ribon cable disconnect: stap 4, afbeelding 1 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, flat ribon cable disconnect: stap 4, afbeelding 2 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, flat ribon cable disconnect: stap 4, afbeelding 3 van 3
    • Lift with the flat side of a spudger the connector from the left and right side until you can easy unplug.
    • Unplug the connector.
  5. CSL TM137U optical vertical mouse 26068 - disassembly, Click upper part - find plastic clips: stap 5, afbeelding 1 van 1
    • Search for the two plastic clips of the click upper part. The first one you can see easily. The second one is hidden under the board.
  6. CSL TM137U optical vertical mouse 26068 - disassembly, Click upper part - plastic clip 1: stap 6, afbeelding 1 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, Click upper part - plastic clip 1: stap 6, afbeelding 2 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, Click upper part - plastic clip 1: stap 6, afbeelding 3 van 3
    • Release the first plastic clip with your fingernail for example. Press the click upper part downwards.
    • The plastic clip must be completely released. The plastic clip must touch the sliding face of the other side.
    • There should be a visible one-sided gap between upper and lower part. An opening pick should fit in the gap.
  7. CSL TM137U optical vertical mouse 26068 - disassembly, Click upper part - plastic clip 2: stap 7, afbeelding 1 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, Click upper part - plastic clip 2: stap 7, afbeelding 2 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, Click upper part - plastic clip 2: stap 7, afbeelding 3 van 3
    • Most difficult part of the disassembly.
    • Use a thin object such as a spudger or a wooden stick to release the second plastic clip.
    • You have to move the stick under the flat ribbon cable and under the board until it reaches the plastic clip.
    • After releasing the second plastic clip the gap between the click upper part and the whole upper part can be increased. You can the remove the whole click upper part.
  8. CSL TM137U optical vertical mouse 26068 - disassembly, Remove screws: stap 8, afbeelding 1 van 1
    • Remove three Phillips screws.
    • The upper part consists of two parts, which are screwed together.
  9. CSL TM137U optical vertical mouse 26068 - disassembly, Split upper part: stap 9, afbeelding 1 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, Split upper part: stap 9, afbeelding 2 van 3 CSL TM137U optical vertical mouse 26068 - disassembly, Split upper part: stap 9, afbeelding 3 van 3
    • Fix the right half of the upper part with your right hand.
    • Move yo
    • Hier Übersetzung einfügen
  10. CSL TM137U optical vertical mouse 26068 - disassembly, Remove screws: stap 10, afbeelding 1 van 2 CSL TM137U optical vertical mouse 26068 - disassembly, Remove screws: stap 10, afbeelding 2 van 2
    • Remove two Phillips screws.
    • Lift carefully the board.
    • Here are all mouse switches visible; colored in blue.
  11. CSL TM137U optical vertical mouse 26068 - disassembly, Remove flat ribbon cable: stap 11, afbeelding 1 van 1
    • Carefully lever with the flat end of a spudger the connector
  12. CSL TM137U optical vertical mouse 26068 - disassembly, Remove screw: stap 12, afbeelding 1 van 1
    • Remove one Phillips screws and then remove the board.
  13. CSL TM137U optical vertical mouse 26068 - disassembly, Overview of parts: stap 13, afbeelding 1 van 1
    • All Phillips screws: Left: 2x screws for click- scrollwheel board || Middle: 1x screw for forward-back-DPI board || right: 6x screws for mounting the upper and lower parts of the case
    • 3x mouse feet
    • click-scrollwheel board
    • forward-back-DPI board
    • scroll wheel
    • lower part of the mouse case
    • two-piece upper part of the mouse case
Conclusie
Reverse the steps to reassemble your device.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Xare
1.850 Reputatie
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 35
Altijd: 454
