Ga door naar hoofdinhoud
CMS Switch Replacement
Wat je nodig hebt
  1. CMS Switch Replacement, Open the handle: stap 1, afbeelding 1 van 3 CMS Switch Replacement, Open the handle: stap 1, afbeelding 2 van 3 CMS Switch Replacement, Open the handle: stap 1, afbeelding 3 van 3
    • Unscrew the 5 screws shown in the first image
    • Unscrew the 4 screws shown in the second image
    • Turn the handle over and remove the black cover shown in the 3rd image.
    Vraag FixBot
    Voeg opmerking toe
  2. CMS Switch Replacement, Open the handle: stap 2, afbeelding 1 van 2 CMS Switch Replacement, Open the handle: stap 2, afbeelding 2 van 2
    • Slowly pull the top half of the stick and rotate it. (Be careful not to damage the wires inside).
    • The red trigger can pop out due to tension from springs, so be careful.
    Vraag FixBot
    Voeg opmerking toe
  3. CMS Switch Replacement, Inspect the insides: stap 3, afbeelding 1 van 1
    • Check the internal connections.
    • Optionally, you can tighten the screw shown in the picture, as it can sometimes be the cause of looseness in the joystick handle and the large gray nut.
    Vraag FixBot
    Voeg opmerking toe
  4. CMS Switch Replacement, Remove the connector: stap 4, afbeelding 1 van 2 CMS Switch Replacement, Remove the connector: stap 4, afbeelding 2 van 2
    • Disconnect the wires from CMS connector, they are highlighted in red.
    • Remove the screws so that you could detach the PCB.
    Vraag FixBot
    Voeg opmerking toe
  5. CMS Switch Replacement, Remove the old CMS: stap 5, afbeelding 1 van 1
    • Hold down the CMS clip which will allow you to remove the switch. If necessary, you can force it out or brake it.
    • Once the old CMS is removed, you can insert the new one
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Be careful not to damage the wires when reattaching the two halves of the joystick handle.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
Bijgevoegde documenten
Avrila
1.362 Reputatie
5 handleidingen geschreven
2Gids Commentaar
Merci pour ces tuto qui peuvent se révéler bien pratique, mais une question demeure, où trouver les pièces de rechanges ! rien sur le site de TM ! ;)
Kervinou - Antwoord Deel
if anyone needs this part, contact thrustmaster support with photos of the joystick and serial number. the support team will reach out about purchasing a new part
Donk - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 37
Altijd: 1,021
