Inleiding
Replacing keycaps is one of the most common operations performed on a keyboard. Follow this guide to learn how to replace large keycaps on your mechanical keyboard.
Wat je nodig hebt
Remove keycaps surrounding the keycap you'd like to remove by following the remove small keycaps guide.
Install the plastic rings on the new keycap. The overhang needs to be ‘facing forward’ so that when the keycap is placed back on the board, the overhang is furthest away from you. When attaching the new key to the board, the ends of the metal bar on the board will go through these rings.
