Ga door naar hoofdinhoud
CASIO CDP-230R Pitch Bend Replacement
Wat je nodig hebt
  1. CASIO CDP-230R Pitch Bend Replacement, Panels: stap 1, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement, Panels: stap 1, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement, Panels: stap 1, afbeelding 3 van 3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
    Vraag FixBot
    Voeg opmerking toe
  2. CASIO CDP-230R Pitch Bend Replacement: stap 2, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 2, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 2, afbeelding 3 van 3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
    Vraag FixBot
    Voeg opmerking toe
  3. CASIO CDP-230R Pitch Bend Replacement: stap 3, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 3, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 3, afbeelding 3 van 3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
    Vraag FixBot
    Voeg opmerking toe
  4. CASIO CDP-230R Pitch Bend Replacement: stap 4, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 4, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 4, afbeelding 3 van 3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  5. CASIO CDP-230R Pitch Bend Replacement: stap 5, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 5, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 5, afbeelding 3 van 3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
    Vraag FixBot
    Voeg opmerking toe
  6. CASIO CDP-230R Pitch Bend Replacement: stap 6, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 6, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 6, afbeelding 3 van 3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
    Vraag FixBot
    Voeg opmerking toe
  7. CASIO CDP-230R Pitch Bend Replacement: stap 7, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 7, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 7, afbeelding 3 van 3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
    Vraag FixBot
    Voeg opmerking toe
  8. CASIO CDP-230R Pitch Bend Replacement: stap 8, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 8, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement: stap 8, afbeelding 3 van 3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
    Vraag FixBot
    Voeg opmerking toe
  9. CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: stap 9, afbeelding 1 van 3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: stap 9, afbeelding 2 van 3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: stap 9, afbeelding 3 van 3
    • Remove the two 8mm x 1.5mm J screws from the inside of the side panel by using a J1 head screwdriver.
    • Slide the pitch bend out of the side panel.
    Vraag FixBot
    Voeg opmerking toe
  10. CASIO CDP-230R Pitch Bend Replacement: stap 10, afbeelding 1 van 2 CASIO CDP-230R Pitch Bend Replacement: stap 10, afbeelding 2 van 2
    • Follow the white and orange cable to the white end that is attached to the button panel
    • Pinch the white end and pull the cord out
    Vraag FixBot
    Voeg opmerking toe
  11. CASIO CDP-230R Pitch Bend Replacement: stap 11, afbeelding 1 van 1
    • Run the white and orange cable through the innermost side panel and pull out
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Areli Reyes
545 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G2, Livingston Fall 2017 Lid van Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 878
