Ga door naar hoofdinhoud
Brother PT-1010 Keyboard Replacement
Wat je nodig hebt
    1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: stap 1, afbeelding 1 van 1
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      Vraag FixBot
      Voeg opmerking toe
    2. Brother PT-1010 Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Remove batteries, cassette tape, and cutter blade.
      Vraag FixBot
      Voeg opmerking toe
    3. Brother PT-1010 Keyboard Replacement, Remove Screws: stap 3, afbeelding 1 van 1
      • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
      Vraag FixBot
      Voeg opmerking toe
    4. Brother PT-1010 Keyboard Replacement, Separate Device: stap 4, afbeelding 1 van 1
      • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
      Vraag FixBot
      Voeg opmerking toe
    5. Brother PT-1010 Keyboard Replacement, Remove side panels: stap 5, afbeelding 1 van 1
      • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
      Vraag FixBot
      Voeg opmerking toe
    6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: stap 6, afbeelding 1 van 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: stap 6, afbeelding 2 van 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: stap 6, afbeelding 3 van 3
      • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
      Vraag FixBot
      Voeg opmerking toe
    7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: stap 7, afbeelding 1 van 1
      • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
      Vraag FixBot
      Voeg opmerking toe
    8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: stap 8, afbeelding 1 van 1
      • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
      • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: stap 9, afbeelding 1 van 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: stap 9, afbeelding 2 van 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: stap 9, afbeelding 3 van 3
      • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Haley Sweet
460 Reputatie
4 handleidingen geschreven
Baylor, Team 4-4, Williams Fall 2014 Lid van Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Leden
23 handleidingen geschreven
3Gids Commentaar
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - Antwoord Deel
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - Antwoord Deel
Screen is dull, what to do
Judy Baranczyk - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 3,670
