Ga door naar hoofdinhoud
Brentwood TS-292B Heating Wire Replacement
Wat je nodig hebt
  1. Brentwood TS-292B Heating Wire Replacement, Heating Wire: stap 1, afbeelding 1 van 2 Brentwood TS-292B Heating Wire Replacement, Heating Wire: stap 1, afbeelding 2 van 2
    • Remove the five screws to loosen the the outer housing from the internal components.
    • Pull up on the black plastic housing until it is dislodged from the base.
  2. Brentwood TS-292B Heating Wire Replacement: stap 2, afbeelding 1 van 3 Brentwood TS-292B Heating Wire Replacement: stap 2, afbeelding 2 van 3 Brentwood TS-292B Heating Wire Replacement: stap 2, afbeelding 3 van 3
    • You will need to remove the toasting lever by removing the black tab from the lever.
    • You will now be able to completely remove the housing from the base of the toaster.
    • You will need small chain nose pliers to check for slack on either end of the broken wire.
    • If there is no slack in the wire, you must buy extra nichrome wire in order to fix your toaster.
  3. Brentwood TS-292B Heating Wire Replacement: stap 4, afbeelding 1 van 1
    • Pull the slack out of the wire and pinch the two ends of the wire together.
    • Gently twist the two ends of the wires together to establish a connection.
    • Disclaimer: The wires are flat so you will require extra wire if you are not able to obtain enough slack.
Conclusie
Elly Ayala
739 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 132
