Ga door naar hoofdinhoud
Braven BRV-X Front Speaker Panel Replacement
Wat je nodig hebt
  1. Braven BRV-X Front Speaker Panel Replacement, Front Speaker Panel: stap 1, afbeelding 1 van 1
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Front Speaker Panel Replacement: stap 2, afbeelding 1 van 1
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Front Speaker Panel Replacement: stap 3, afbeelding 1 van 1
    • Gently remove the outer shell.
  4. Braven BRV-X Front Speaker Panel Replacement: stap 4, afbeelding 1 van 2 Braven BRV-X Front Speaker Panel Replacement: stap 4, afbeelding 2 van 2
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Front Speaker Panel Replacement: stap 5, afbeelding 1 van 2 Braven BRV-X Front Speaker Panel Replacement: stap 5, afbeelding 2 van 2
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Front Speaker Panel Replacement: stap 6, afbeelding 1 van 3 Braven BRV-X Front Speaker Panel Replacement: stap 6, afbeelding 2 van 3 Braven BRV-X Front Speaker Panel Replacement: stap 6, afbeelding 3 van 3
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Front Speaker Panel Replacement: stap 7, afbeelding 1 van 2 Braven BRV-X Front Speaker Panel Replacement: stap 7, afbeelding 2 van 2
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Front Speaker Panel Replacement: stap 8, afbeelding 1 van 2 Braven BRV-X Front Speaker Panel Replacement: stap 8, afbeelding 2 van 2
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Front Speaker Panel Replacement: stap 9, afbeelding 1 van 1
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Front Speaker Panel Replacement: stap 10, afbeelding 1 van 2 Braven BRV-X Front Speaker Panel Replacement: stap 10, afbeelding 2 van 2
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Front Speaker Panel Replacement: stap 11, afbeelding 1 van 3 Braven BRV-X Front Speaker Panel Replacement: stap 11, afbeelding 2 van 3 Braven BRV-X Front Speaker Panel Replacement: stap 11, afbeelding 3 van 3
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Front Speaker Panel Replacement: stap 12, afbeelding 1 van 3 Braven BRV-X Front Speaker Panel Replacement: stap 12, afbeelding 2 van 3 Braven BRV-X Front Speaker Panel Replacement: stap 12, afbeelding 3 van 3
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
Conclusie
Trey Peterson
301 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G5, Harley Spring 2019 Lid van IUPUI, Team S1-G5, Harley Spring 2019
IUPUI-HARLEY-S19S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 253
