Ga door naar hoofdinhoud
Braven BRV-X Battery Replacement
Wat je nodig hebt
    1. Braven BRV-X Battery Replacement, Bottom Outer Casing: stap 1, afbeelding 1 van 3 Braven BRV-X Battery Replacement, Bottom Outer Casing: stap 1, afbeelding 2 van 3 Braven BRV-X Battery Replacement, Bottom Outer Casing: stap 1, afbeelding 3 van 3
      • Flip the Braven BRV-X upside down so you are facing the bottom side.
      • With the H1.5 Head Screwdriver, unscrew the four screws.
      • All screws on this device can be stripped easily. Hold your screwdriver with the thumb on top and swivel with the opposite hand's thumb and index finger.
      • Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
      • Gently remove the outer casing, which should reveal the inner shell.
      Vraag FixBot
      Voeg opmerking toe
    2. Braven BRV-X Battery Replacement: stap 2, afbeelding 1 van 2 Braven BRV-X Battery Replacement: stap 2, afbeelding 2 van 2
      • With a Jimmy, cut the two warranty seals on either side.
      • You may also use a tech knife instead of a Jimmy.
      • WARNING: Once warranty seals are broken, you may no longer return the product.
      • Next, remove the 18 screws with a #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Braven BRV-X Battery Replacement: stap 3, afbeelding 1 van 2 Braven BRV-X Battery Replacement: stap 3, afbeelding 2 van 2
      • Using two plastic opening tools, slide under the cover and slowly lift.
      • There is glue nearly all around the inner shell, so strength will be necessary. When both tools are inserted, you can slide out along the edges.
      Vraag FixBot
      Voeg opmerking toe
    1. Braven BRV-X Battery Replacement, Battery: stap 4, afbeelding 1 van 1
      • Remove the black foam squares from the red, yellow, and black wire on the top right side of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Braven BRV-X Battery Replacement: stap 5, afbeelding 1 van 3 Braven BRV-X Battery Replacement: stap 5, afbeelding 2 van 3 Braven BRV-X Battery Replacement: stap 5, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Now that the three wires are exposed, follow the wires to the white base that is plugged into the motherboard.
      • Using the tech knife, carefully remove the glue that keeps the plug in place.
      • Using the tweezers, carefully disconnect the plug from the motherboard.
      • WARNING: Make sure the battery is drained of all power for safety reasons.
      • There should still be a small white base attached to the motherboard, where the plug will eventually be plugged back in.
      Vraag FixBot
      Voeg opmerking toe
    3. Braven BRV-X Battery Replacement: stap 6, afbeelding 1 van 1
      • The battery's black shell is connected to the motherboard with four screws. Use the #00 Phillips screwdriver to remove the four screws.
      • The screws near the speaker side of the device will be a tight squeeze to get to.
      Vraag FixBot
      Voeg opmerking toe
    4. Braven BRV-X Battery Replacement: stap 7, afbeelding 1 van 1
      • Now, you should be able to lift the battery along with the black container up.
      • Pull the battery pack straight out so you do not damage other wires or the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Braven BRV-X Battery Replacement: stap 8, afbeelding 1 van 1
      • Slide the blue battery out from the black container. Your battery is now removed from the device and is ready for replacement.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Courtney Crockett
374 Reputatie
2 handleidingen geschreven
Texas Tech, Team 19-4, Rauch Fall 2015 Lid van Texas Tech, Team 19-4, Rauch Fall 2015
TTU-RAUCH-F15S19G4
4 Leden
16 handleidingen geschreven
11Gids Commentaar
Thank you for the replacement steps - do you know where I could buy a replacement battery?
jmckeag7 - Antwoord Deel
Anyone ever figure out what battery they needed?
Aaron Eisenbarth - Antwoord Deel
I also would love to know what battery is actually needed for this.
grenchpickle - Antwoord Deel
The batteries are two 18650's in tandem. You can get these from batteries plus
nick - Antwoord Deel
Parallel or series connection?
Vladimir Skrbic - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 89
Altijd: 11,888
