Ga door naar hoofdinhoud
Bose Soundlink Revolve Top Circuit Board Replacement
Wat je nodig hebt
    1. Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: stap 1, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: stap 1, afbeelding 2 van 2
      • Flip speaker over so that the bottom is facing up.
      • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
      Vraag FixBot
      Voeg opmerking toe
    2. Bose Soundlink Revolve Top Circuit Board Replacement: stap 2, afbeelding 1 van 3 Bose Soundlink Revolve Top Circuit Board Replacement: stap 2, afbeelding 2 van 3 Bose Soundlink Revolve Top Circuit Board Replacement: stap 2, afbeelding 3 van 3
      • Using the screwdriver, unscrew three screws.
      • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
      Vraag FixBot
      Voeg opmerking toe
    3. Bose Soundlink Revolve Top Circuit Board Replacement: stap 3, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 3, afbeelding 2 van 2
      • Remove the screw that is above the charging port.
      Vraag FixBot
      Voeg opmerking toe
    4. Bose Soundlink Revolve Top Circuit Board Replacement: stap 4, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 4, afbeelding 2 van 2
      • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
      • Remove the bottom cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Bose Soundlink Revolve Top Circuit Board Replacement, Top Circuit Board: stap 5, afbeelding 1 van 1
      • Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
      Vraag FixBot
      Voeg opmerking toe
    2. Bose Soundlink Revolve Top Circuit Board Replacement: stap 6, afbeelding 1 van 1
      • Remove the (4) four screws shown around the top of the inside.
      • (2) two of the screws are shown here, the other side will look the same.
      Vraag FixBot
      Voeg opmerking toe
    3. Bose Soundlink Revolve Top Circuit Board Replacement: stap 7, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 7, afbeelding 2 van 2
      • Pry up and remove the soft plastic casing from the rest of the device.
      Vraag FixBot
      Voeg opmerking toe
    4. Bose Soundlink Revolve Top Circuit Board Replacement: stap 8, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 8, afbeelding 2 van 2
      • Remove the 3 screws holding down the top circuit board.
      Vraag FixBot
      Voeg opmerking toe
    5. Bose Soundlink Revolve Top Circuit Board Replacement: stap 9, afbeelding 1 van 1
      • Lift up and look on the underside of the circuit board.
      • Using the plastic opening tool, pry open the wide clamp keeping a ribbon to the top circuit board. The top circuit board can now freely be removed from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
Brian Butner
927 Reputatie
3 handleidingen geschreven
USF Tampa, Team S6-G2, Remmell Fall 2017 Lid van USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Leden
12 handleidingen geschreven
13Gids Commentaar
Hello,
I need to buy the TOP CIRCUIT BOARD … Where Can I buy it or could you sell me one ? Thank you my mail is skelet300@gmail.com
skelet300 - Antwoord Deel
I also need one of these boards and don’t really want to buy a complete used unit to repair mine, copydoc1@aol.com if you know of any resources, thanks in advance.
Jeff Pitt - Antwoord Deel
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
fmpitschieller - Antwoord Deel
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
Fay Claybrook - Antwoord Deel
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
Michael Parsche - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 127
Altijd: 15,868
