Ga door naar hoofdinhoud
Bose Soundlink Flex Radiator Replacement
Wat je nodig hebt
  1. Bose Soundlink Flex Radiator Replacement, Grille: stap 1, afbeelding 1 van 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Vraag FixBot
    Voeg opmerking toe
  2. Bose Soundlink Flex Radiator Replacement: stap 2, afbeelding 1 van 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Bose Soundlink Flex Radiator Replacement: stap 3, afbeelding 1 van 2 Bose Soundlink Flex Radiator Replacement: stap 3, afbeelding 2 van 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Vraag FixBot
    Voeg opmerking toe
  4. Bose Soundlink Flex Radiator Replacement, Radiator: stap 4, afbeelding 1 van 3 Bose Soundlink Flex Radiator Replacement, Radiator: stap 4, afbeelding 2 van 3 Bose Soundlink Flex Radiator Replacement, Radiator: stap 4, afbeelding 3 van 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Vraag FixBot
    Voeg opmerking toe
  5. Bose Soundlink Flex Radiator Replacement: stap 5, afbeelding 1 van 2 Bose Soundlink Flex Radiator Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Bose Soundlink Flex Radiator Replacement: stap 6, afbeelding 1 van 3 Bose Soundlink Flex Radiator Replacement: stap 6, afbeelding 2 van 3 Bose Soundlink Flex Radiator Replacement: stap 6, afbeelding 3 van 3
    • Pull the backplate off to expose both sides of the radiator.
    Vraag FixBot
    Voeg opmerking toe
  7. Bose Soundlink Flex Radiator Replacement: stap 7, afbeelding 1 van 3 Bose Soundlink Flex Radiator Replacement: stap 7, afbeelding 2 van 3 Bose Soundlink Flex Radiator Replacement: stap 7, afbeelding 3 van 3
    • Remove the four 2.3 mm corner screws using a TR8 Torx screwdriver.
    • Remove the two 1.7 mm screws using a TR6 Torx screwdriver.
    • Follow this step for both radiators.
    Vraag FixBot
    Voeg opmerking toe
  8. Bose Soundlink Flex Radiator Replacement: stap 8, afbeelding 1 van 2 Bose Soundlink Flex Radiator Replacement: stap 8, afbeelding 2 van 2
    • Remove the radiator and replace with the new radiator.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Monica Silva
262 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 53
Altijd: 985
