Ga door naar hoofdinhoud
Bose Soundlink Flex Driver Replacement
Wat je nodig hebt
  1. Bose Soundlink Flex Driver Replacement, Grille: stap 1, afbeelding 1 van 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Vraag FixBot
    Voeg opmerking toe
  2. Bose Soundlink Flex Driver Replacement: stap 2, afbeelding 1 van 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Bose Soundlink Flex Driver Replacement: stap 3, afbeelding 1 van 2 Bose Soundlink Flex Driver Replacement: stap 3, afbeelding 2 van 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Vraag FixBot
    Voeg opmerking toe
  4. Bose Soundlink Flex Driver Replacement, Driver: stap 4, afbeelding 1 van 3 Bose Soundlink Flex Driver Replacement, Driver: stap 4, afbeelding 2 van 3 Bose Soundlink Flex Driver Replacement, Driver: stap 4, afbeelding 3 van 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Vraag FixBot
    Voeg opmerking toe
  5. Bose Soundlink Flex Driver Replacement: stap 5, afbeelding 1 van 3 Bose Soundlink Flex Driver Replacement: stap 5, afbeelding 2 van 3 Bose Soundlink Flex Driver Replacement: stap 5, afbeelding 3 van 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Bose Soundlink Flex Driver Replacement: stap 6, afbeelding 1 van 2 Bose Soundlink Flex Driver Replacement: stap 6, afbeelding 2 van 2
    • Desolder the joints that are connecting the speaker to the motherboard.
    • Solder the new speaker with the wire color in the same order.
    • Be cautious when removing and adding the solder to not damage the motherboard or burn yourself.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Kalvin Lee
625 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 119
Altijd: 1,829
