Ga door naar hoofdinhoud
Bose Soundlink Flex Battery Replacement
Wat je nodig hebt
  1. Bose Soundlink Flex Battery Replacement, Grille: stap 1, afbeelding 1 van 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Vraag FixBot
    Voeg opmerking toe
  2. Bose Soundlink Flex Battery Replacement: stap 2, afbeelding 1 van 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Bose Soundlink Flex Battery Replacement: stap 3, afbeelding 1 van 2 Bose Soundlink Flex Battery Replacement: stap 3, afbeelding 2 van 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Vraag FixBot
    Voeg opmerking toe
  4. Bose Soundlink Flex Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Bose Soundlink Flex Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Bose Soundlink Flex Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Vraag FixBot
    Voeg opmerking toe
  5. Bose Soundlink Flex Battery Replacement: stap 5, afbeelding 1 van 3 Bose Soundlink Flex Battery Replacement: stap 5, afbeelding 2 van 3 Bose Soundlink Flex Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Bose Soundlink Flex Battery Replacement: stap 6, afbeelding 1 van 2 Bose Soundlink Flex Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Bose Soundlink Flex Battery Replacement: stap 7, afbeelding 1 van 3 Bose Soundlink Flex Battery Replacement: stap 7, afbeelding 2 van 3 Bose Soundlink Flex Battery Replacement: stap 7, afbeelding 3 van 3
    • Take the motherboard out and take note of the battery attached.
    • Remove the insulation and the solder from the wiring.
    • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
    • Solder the wires of the new battery onto the motherboard.
    • Be cautious when adding the solder to not damage the motherboard or burn yourself.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Kalvin Lee
625 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
3 Leden
15 handleidingen geschreven
1Gids Commentaar
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
SOM SATPATHY - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 95
Afgelopen 30 dagen: 469
Altijd: 8,414
