Ga door naar hoofdinhoud
Bose SoundDock Portable v2 Speaker Replacement
Wat je nodig hebt
  1. Bose SoundDock Portable v2 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Gently pry the front mesh cover off of the SoundDock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart
  2. Bose SoundDock Portable v2 Speaker Replacement: stap 2, afbeelding 1 van 2 Bose SoundDock Portable v2 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
    • Gently lift the speaker from the base.
    • Do not lift the speaker to far out of the base, you may damage the wires.
  3. Bose SoundDock Portable v2 Speaker Replacement: stap 3, afbeelding 1 van 1
    • You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Evan Low
551 Reputatie
4 handleidingen geschreven
Cal Poly, Team 4-1, Maness Spring 2015 Lid van Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Leden
5 handleidingen geschreven
5 opmerkingen
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
vero198099 - Antwoord
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
AJ Grape - Antwoord
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Colm Donnelly -
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
Chantelle Webb - Antwoord
How do you cut on without remote
Chad Davenport - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 31
Altijd: 11,789
