Ga door naar hoofdinhoud
Bose SoundDock Portable v2 Remote Battery Replacement
Wat je nodig hebt
    1. Bose SoundDock Portable v2 Remote Battery Replacement, Remote Battery: stap 1, afbeelding 1 van 1
      • Using a quarter, turn the battery cover 1/8th of a turn counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. Bose SoundDock Portable v2 Remote Battery Replacement: stap 2, afbeelding 1 van 2 Bose SoundDock Portable v2 Remote Battery Replacement: stap 2, afbeelding 2 van 2
      • Remove cover and battery. The new battery should be placed with the positive (flat) side facing up.
      • The correct battery for your remote is a CR2032. You may also use a DL2032.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Brodie Sutherland
333 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-1, Maness Spring 2015 Lid van Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Leden
10 handleidingen geschreven
1Gids Commentaar
We have a Bose Wave radio w/remote. This remote is not the one shown here with a screw for the battery compartment. It's the type w/a sliding holder for the battery on the south end (bottom of the battery). Someone went to replace the battery and shoved the holder in upside down I believe. Consequently the holder will not come out all the way.
There must be a way to get it out without forcing it. There's a pinch clip you have to either squeeze or move to the left to disengage it from the locked position and free it up. Any ideas as to how to accomplish this? We appreciate a reply back so this would make our Christmas better.
Merry Christmas & Happy Holidays! Cheers!
asbirdiesingh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 151
Altijd: 16,033
