Ga door naar hoofdinhoud
Bose QuietComfort 25 Motherboard Replacement
Wat je nodig hebt
  1. Bose QuietComfort 25 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Begin repair by removing the ear cushion.
    • The cushion is held on by a few small plastic clips. Pry carefully with plastic opening tool or fingernails.
  2. Bose QuietComfort 25 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Next, remove the soft lining behind the cushion. This is held on with adhesive and is easily removed by hand.
  3. Bose QuietComfort 25 Motherboard Replacement: stap 3, afbeelding 1 van 3 Bose QuietComfort 25 Motherboard Replacement: stap 3, afbeelding 2 van 3 Bose QuietComfort 25 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Once the soft lining is removed from behind the ear cushion, two screws will be exposed.
    • Carefully remove the two 5 mm screws with a precision screwdriver (PH00) and put aside.
  4. Bose QuietComfort 25 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Flip the earphones back over and carefully pry around the outside cover of the earpiece.
    • Try a plastic opening tool before moving on to harder metal tools.
    • This cover will come loose with moderate pressure.
  5. Bose QuietComfort 25 Motherboard Replacement: stap 5, afbeelding 1 van 3 Bose QuietComfort 25 Motherboard Replacement: stap 5, afbeelding 2 van 3 Bose QuietComfort 25 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • There are 3 screws holding the motherboard to the earpiece.
    • Remove these screws to make the next step easier.
  6. Bose QuietComfort 25 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Once the motherboard is exposed, all of the soldered connection will need to be removed.
    • Be careful of this step and take note of the position of each wire.
    • This should only be attempted by someone with experience soldering small components, as irreparable damage may be result from improper methods. For help with this step see this guide on Hoe moet je (de-)solderen?
  7. Bose QuietComfort 25 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • After removing all the soldered joints, the motherboard can be removed by hand.
    • The connections will all need to be re-soldered into their respective locations.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Samuel Coss
339 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G3, Harley Spring 2018 Lid van IUPUI, Team S2-G3, Harley Spring 2018
IUPUI-HARLEY-S18S2G3
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 83
Altijd: 11,321
