Ga door naar hoofdinhoud
Bose Quiet Comfort 35 II Audio Jack Connector Replacement
Wat je nodig hebt
  1. Bose Quiet Comfort 35 II Audio Jack Connector Replacement, Audio Jack Cable Connector: stap 1, afbeelding 1 van 1
    • Take off ear cushion pad using the plastic opening tool. Pry until you notice the seam of the ear cushion separates from the plastic tabs.
  2. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 2, afbeelding 1 van 3 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 2, afbeelding 2 van 3 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 2, afbeelding 3 van 3
    • Take off the ear cover by peeling off the glue with hands.
  3. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 3, afbeelding 1 van 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 7-millimeter silver screws from the inside by using the Phillips #000 screwdriver to disconnect the back cover.
  4. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 4, afbeelding 1 van 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 5-millimeter silver screws attaching the earphones to the headband using the Phillips #000 screwdriver.
  5. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 5, afbeelding 1 van 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 5, afbeelding 2 van 2
    • Detach the earpiece form the band using the flat part of the metal spudger.
    • Slide the joint at the end of the headphone band out to release ear piece.
  6. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 6, afbeelding 1 van 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 6, afbeelding 2 van 2
    • Detach the silver cover on the outside of the headset using the spudger.
    • Pry until you hear a distinct pop; this indicates the cover has separated from its base.
  7. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 7, afbeelding 1 van 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 7, afbeelding 2 van 2
    • Solder off the ribbon cable from the driver near the cable connector port to detach it.
  8. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 8, afbeelding 1 van 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: stap 8, afbeelding 2 van 2
    • Replace the cable connector with spare driver/audio jack combo.
    • Optional: desolder the five audio jack posts seen here, and replace individual audio jack.
Conclusie
kssexton
463 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-2, Harley Fall 2023 Lid van IUPUI, Team 1-2, Harley Fall 2023
IUPUI-HARLEY-F23S1G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 58
Altijd: 481
