Inleiding
This guide explains how to replace a belt on the Boosted Board Mini Electric Skateboard. This guide is necessary because if the skateboard belt has become over worn or has snapped off, then the board becomes unusable. We will demonstrate how to replace the belt that is attached to the motor in order to regain the function of the electric skateboard.
Wat je nodig hebt
Unscrew the axle nut holding the wheel in place with your wrench on the side of the board where the belt has snapped/became worn.
If the belt on the other side of the skateboard also needs to be replaced, repeat steps 1-16.
Één andere persoon heeft deze handleiding voltooid.
