Ga door naar hoofdinhoud
Boosted Board 1st Generation Rear Wheels Replacement
Wat je nodig hebt
  1. Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: stap 1, afbeelding 1 van 2 Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: stap 1, afbeelding 2 van 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Rear Wheels Replacement: stap 2, afbeelding 1 van 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Rear Wheels Replacement: stap 3, afbeelding 1 van 2 Boosted Board 1st Generation Rear Wheels Replacement: stap 3, afbeelding 2 van 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Rear Wheels Replacement: stap 4, afbeelding 1 van 3 Boosted Board 1st Generation Rear Wheels Replacement: stap 4, afbeelding 2 van 3 Boosted Board 1st Generation Rear Wheels Replacement: stap 4, afbeelding 3 van 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
Conclusie
Emily Imfeld
532 Reputatie
4 handleidingen geschreven
Cal Poly, Team 15-7, Livingston Fall 2016 Lid van Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,268
