Ga door naar hoofdinhoud
Body Panel Removal
Wat je nodig hebt
  1. Body Panel Removal, Remove film door: stap 1, afbeelding 1 van 1
    • Push down the latch to release the film door.
    Vraag FixBot
    Voeg opmerking toe
  2. Body Panel Removal, Remove top cover screws: stap 2, afbeelding 1 van 3 Body Panel Removal, Remove top cover screws: stap 2, afbeelding 2 van 3 Body Panel Removal, Remove top cover screws: stap 2, afbeelding 3 van 3
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  3. Body Panel Removal, Remove top cover screws: stap 3, afbeelding 1 van 3 Body Panel Removal, Remove top cover screws: stap 3, afbeelding 2 van 3 Body Panel Removal, Remove top cover screws: stap 3, afbeelding 3 van 3
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
    Vraag FixBot
    Voeg opmerking toe
  4. Body Panel Removal, Lift top cover: stap 4, afbeelding 1 van 1
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
    Vraag FixBot
    Voeg opmerking toe
  5. Body Panel Removal, Access flash connections: stap 5, afbeelding 1 van 2 Body Panel Removal, Access flash connections: stap 5, afbeelding 2 van 2
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
    Vraag FixBot
    Voeg opmerking toe
  6. Body Panel Removal, Discharge flash capacitors: stap 6, afbeelding 1 van 1
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    Vraag FixBot
    Voeg opmerking toe
  7. Body Panel Removal, Disconnect right flex cable: stap 7, afbeelding 1 van 1
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
    Vraag FixBot
    Voeg opmerking toe
  8. Body Panel Removal, Disconnect left flex cable: stap 8, afbeelding 1 van 1
    • Desolder the red wire.
    Vraag FixBot
    Voeg opmerking toe
  9. Body Panel Removal, Desolder flash connections: stap 9, afbeelding 1 van 2 Body Panel Removal, Desolder flash connections: stap 9, afbeelding 2 van 2
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
    Vraag FixBot
    Voeg opmerking toe
  10. Body Panel Removal, Desolder the flash flex cable: stap 10, afbeelding 1 van 2 Body Panel Removal, Desolder the flash flex cable: stap 10, afbeelding 2 van 2
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
    Vraag FixBot
    Voeg opmerking toe
  11. Body Panel Removal, Remove bottom cover: stap 11, afbeelding 1 van 3 Body Panel Removal, Remove bottom cover: stap 11, afbeelding 2 van 3 Body Panel Removal, Remove bottom cover: stap 11, afbeelding 3 van 3
    • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
    • Remove one 5mm #00 screw.
    • Remove one 7.5mm #00 screw.
    • Remove two 4.5mm #00 screws.
    • Remove one 5.5mm #00 screw.
    • Remove the plastic frame around the accessory grip contacts.
    • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
    Vraag FixBot
    Voeg opmerking toe
  12. Body Panel Removal, Remove front left cover: stap 12, afbeelding 1 van 1
    • Remove one 4.0 mm #00 screw.
    • Remove left cover.
    Vraag FixBot
    Voeg opmerking toe
  13. Body Panel Removal, Remove front cover: stap 13, afbeelding 1 van 1
    • Remove front cover.
    Vraag FixBot
    Voeg opmerking toe
  14. Body Panel Removal, Unscrew front right cover: stap 14, afbeelding 1 van 3 Body Panel Removal, Unscrew front right cover: stap 14, afbeelding 2 van 3 Body Panel Removal, Unscrew front right cover: stap 14, afbeelding 3 van 3
    • Remove one 6.0 mm #00 screw.
    • Remove two 3.5 mm #00 screws.
    • Remove one 5.0 mm #00 screw.
    • Remove the strap lug.
    Vraag FixBot
    Voeg opmerking toe
  15. Body Panel Removal, Remove the front right cover: stap 15, afbeelding 1 van 1
    • Carefully pull the right panel away from the body. It is still attached.
    • Desolder the flex connections.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sam Gustafson
11.000 Reputatie
78 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 52
Altijd: 569
