Ga door naar hoofdinhoud
Blu Studio Selfie Midframe Replacement
Wat je nodig hebt
  1. Blu Studio Selfie Midframe Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
    Vraag FixBot
    Voeg opmerking toe
  2. Blu Studio Selfie Midframe Replacement: stap 2, afbeelding 1 van 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
    Vraag FixBot
    Voeg opmerking toe
  3. Blu Studio Selfie Midframe Replacement, Battery: stap 3, afbeelding 1 van 2 Blu Studio Selfie Midframe Replacement, Battery: stap 3, afbeelding 2 van 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Blu Studio Selfie Midframe Replacement, Midframe: stap 4, afbeelding 1 van 1
    • Remove all the 4mm Phillips #000 screws from the midframe.
    Vraag FixBot
    Voeg opmerking toe
  5. Blu Studio Selfie Midframe Replacement: stap 5, afbeelding 1 van 1
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    Vraag FixBot
    Voeg opmerking toe
  6. Blu Studio Selfie Midframe Replacement: stap 6, afbeelding 1 van 1
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
Samuel McCandless
170 Reputatie
1 Handleiding geschreven
USF Tampa, Team 10-1, Remmell Spring 2016 Lid van USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 724
