Ga door naar hoofdinhoud
Blu Studio 5.5 Volume Control Replacement
Wat je nodig hebt
  1. Blu Studio 5.5 Volume Control Replacement, Battery: stap 1, afbeelding 1 van 3 Blu Studio 5.5 Volume Control Replacement, Battery: stap 1, afbeelding 2 van 3 Blu Studio 5.5 Volume Control Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Volume Control Replacement: stap 2, afbeelding 1 van 2 Blu Studio 5.5 Volume Control Replacement: stap 2, afbeelding 2 van 2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Volume Control Replacement: stap 3, afbeelding 1 van 3 Blu Studio 5.5 Volume Control Replacement: stap 3, afbeelding 2 van 3 Blu Studio 5.5 Volume Control Replacement: stap 3, afbeelding 3 van 3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Volume Control Replacement, Back Panel Assembly: stap 4, afbeelding 1 van 2 Blu Studio 5.5 Volume Control Replacement, Back Panel Assembly: stap 4, afbeelding 2 van 2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Volume Control Replacement: stap 5, afbeelding 1 van 3 Blu Studio 5.5 Volume Control Replacement: stap 5, afbeelding 2 van 3 Blu Studio 5.5 Volume Control Replacement: stap 5, afbeelding 3 van 3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. Blu Studio 5.5 Volume Control Replacement, Volume Control: stap 6, afbeelding 1 van 3 Blu Studio 5.5 Volume Control Replacement, Volume Control: stap 6, afbeelding 2 van 3 Blu Studio 5.5 Volume Control Replacement, Volume Control: stap 6, afbeelding 3 van 3
    • Once the back panel is removed, locate the volume controller.
    • Grab the volume controller with either your fingers or tweezers and gently remove from the phone.
    • Set replaced volume controller aside and gently insert replacement controller.
Conclusie
Jair Riech
173 Reputatie
1 Handleiding geschreven
USF Tampa, Team S1-G6, Nance Spring 2017 Lid van USF Tampa, Team S1-G6, Nance Spring 2017
USFT-NANCE-S17S1G6
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 7
Altijd: 183
