Ga door naar hoofdinhoud
Blu Grand M2 Display Replacement
Wat je nodig hebt
  1. Blu Grand M2 Display Replacement, Display: stap 1, afbeelding 1 van 2 Blu Grand M2 Display Replacement, Display: stap 1, afbeelding 2 van 2
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
    Vraag FixBot
    Voeg opmerking toe
  2. Blu Grand M2 Display Replacement: stap 2, afbeelding 1 van 1
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
    Vraag FixBot
    Voeg opmerking toe
  3. Blu Grand M2 Display Replacement: stap 3, afbeelding 1 van 3 Blu Grand M2 Display Replacement: stap 3, afbeelding 2 van 3 Blu Grand M2 Display Replacement: stap 3, afbeelding 3 van 3
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
    Vraag FixBot
    Voeg opmerking toe
  4. Blu Grand M2 Display Replacement: stap 4, afbeelding 1 van 2 Blu Grand M2 Display Replacement: stap 4, afbeelding 2 van 2
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
    Vraag FixBot
    Voeg opmerking toe
  5. Blu Grand M2 Display Replacement: stap 5, afbeelding 1 van 1
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
    Vraag FixBot
    Voeg opmerking toe
  6. Blu Grand M2 Display Replacement: stap 6, afbeelding 1 van 3 Blu Grand M2 Display Replacement: stap 6, afbeelding 2 van 3 Blu Grand M2 Display Replacement: stap 6, afbeelding 3 van 3
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Christopher
192 Reputatie
1 Handleiding geschreven
Gateway, Team S1-G3, Luster Fall 2018 Lid van Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Leden
12 handleidingen geschreven
1Gids Commentaar
What type of torx screwdriver did you use?
npyles86 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 39
Altijd: 2,221
