Ga door naar hoofdinhoud
Blu Dash 5.0 Dual SIM Display Cable Replacement
Wat je nodig hebt
  1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
    Vraag FixBot
    Voeg opmerking toe
  2. Blu Dash 5.0 Dual SIM Display Cable Replacement: stap 2, afbeelding 1 van 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
    Vraag FixBot
    Voeg opmerking toe
  3. Blu Dash 5.0 Dual SIM Display Cable Replacement, Display Cable: stap 3, afbeelding 1 van 1
    • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
    • The screw holes with the red circle around them hold screws with a 3.5 mm length.
    • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
    Vraag FixBot
    Voeg opmerking toe
  4. Blu Dash 5.0 Dual SIM Display Cable Replacement: stap 4, afbeelding 1 van 2 Blu Dash 5.0 Dual SIM Display Cable Replacement: stap 4, afbeelding 2 van 2
    • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
    • Do this for each corner until the panel pops up.
    Vraag FixBot
    Voeg opmerking toe
  5. Blu Dash 5.0 Dual SIM Display Cable Replacement: stap 5, afbeelding 1 van 3 Blu Dash 5.0 Dual SIM Display Cable Replacement: stap 5, afbeelding 2 van 3 Blu Dash 5.0 Dual SIM Display Cable Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
    • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Dashaya Toney
876 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-7, Miles Fall 2014 Lid van UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 3,380
