Ga door naar hoofdinhoud
Blackberry 8110 Keyboard Replacement
Wat je nodig hebt
  1. Blackberry 8110 Keyboard Replacement, Removing the back cover.: stap 1, afbeelding 1 van 2 Blackberry 8110 Keyboard Replacement, Removing the back cover.: stap 1, afbeelding 2 van 2
    • Turn the phone over so that the screen is facing the table. Locate the chrome release button and push it in to unclip the battery cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Blackberry 8110 Keyboard Replacement, Removing the screws.: stap 2, afbeelding 1 van 2 Blackberry 8110 Keyboard Replacement, Removing the screws.: stap 2, afbeelding 2 van 2
    • Now that the battery cover has been removed, locate the two 7.5mm Torx #T6 screws at the top of the phone. Remove these by turning counter-clockwise with your T6 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Blackberry 8110 Keyboard Replacement, Removing the bottom cover.: stap 3, afbeelding 1 van 2 Blackberry 8110 Keyboard Replacement, Removing the bottom cover.: stap 3, afbeelding 2 van 2
    • Now that the two screws at the top have been removed, take your spudger and locate the two gaps to the left and right of the button that releases the battery cover.
    • With your spudger, carefully wedge it into the gap and pry downwards to release the bottom cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Blackberry 8110 Keyboard Replacement, Removing the screws on the front side.: stap 4, afbeelding 1 van 2 Blackberry 8110 Keyboard Replacement, Removing the screws on the front side.: stap 4, afbeelding 2 van 2
    • Turn the phone over so that the screen is facing up. With the bottom cover off, you will be able to locate two 7.5mm Torx #T6 screws in each corner below the keyboard. Carefully remove these.
    Vraag FixBot
    Voeg opmerking toe
  5. Blackberry 8110 Keyboard Replacement, Taking off the side panels.: stap 5, afbeelding 1 van 3 Blackberry 8110 Keyboard Replacement, Taking off the side panels.: stap 5, afbeelding 2 van 3 Blackberry 8110 Keyboard Replacement, Taking off the side panels.: stap 5, afbeelding 3 van 3
    • Now that the screws on the front have been removed, take your spudger and wedge it between the trim on the side of the phone, and the phone itself. Carefully pry the trim away from the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Blackberry 8110 Keyboard Replacement, Removing the back panel: stap 6, afbeelding 1 van 2 Blackberry 8110 Keyboard Replacement, Removing the back panel: stap 6, afbeelding 2 van 2
    • You are now ready to remove the back panel. In order to do this, locate the two clips on each side of the phone (underneath the trim that you just removed).
    • Once you locate these clips (four in total, two on each side), you should be able to unclip them with your fingers.
    • Be gentle as to not break the clips in doing so.
    Vraag FixBot
    Voeg opmerking toe
  7. Blackberry 8110 Keyboard Replacement, Removing the front panel.: stap 7, afbeelding 1 van 2 Blackberry 8110 Keyboard Replacement, Removing the front panel.: stap 7, afbeelding 2 van 2
    • The front panel is now ready to be removed from the rest of the phone. To do this, just pry the front part (with the keyboard and screen) away from the logic board of the phone with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  8. Blackberry 8110 Keyboard Replacement, Replacing the keyboard.: stap 8, afbeelding 1 van 2 Blackberry 8110 Keyboard Replacement, Replacing the keyboard.: stap 8, afbeelding 2 van 2
    • You are now ready to replace the keyboard! To do this, hold the front screen with the keyboard, and it should fall right out if you push it through the front screen.
    • To install the new keyboard, place it on top of the front screen and seat it in place with the grooves.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Yaqoub Alshawaf
201 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-2, Brown Fall 2014 Lid van USF Tampa, Team 1-2, Brown Fall 2014
USFT-BROWN-F14S1G2
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 592
