Ga door naar hoofdinhoud
BlackBerry Curve 8530 Keypad Replacement
Wat je nodig hebt
    1. BlackBerry Curve 8530 Keypad Replacement, Battery: stap 1, afbeelding 1 van 2 BlackBerry Curve 8530 Keypad Replacement, Battery: stap 1, afbeelding 2 van 2
      • Place the phone on a flat surface with the screen facing down.
      • Remove the plastic backplate by pulling up on the bottom of the cover.
      Vraag FixBot
      Voeg opmerking toe
    2. BlackBerry Curve 8530 Keypad Replacement: stap 2, afbeelding 1 van 1
      • Remove the battery by pulling up from the top of the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. BlackBerry Curve 8530 Keypad Replacement, Keypad: stap 3, afbeelding 1 van 2 BlackBerry Curve 8530 Keypad Replacement, Keypad: stap 3, afbeelding 2 van 2
      • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
      • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
      Vraag FixBot
      Voeg opmerking toe
    2. BlackBerry Curve 8530 Keypad Replacement: stap 4, afbeelding 1 van 2 BlackBerry Curve 8530 Keypad Replacement: stap 4, afbeelding 2 van 2
      • Flip the phone over so the keyboard faces up.
      • Insert a plastic spudger into the screen where speaker resides.
      • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
      • Gently lift up plastic screen cover until screen cover separates from screen.
      • Continue until screen cover is completely removed.
      Vraag FixBot
      Voeg opmerking toe
    3. BlackBerry Curve 8530 Keypad Replacement: stap 5, afbeelding 1 van 3 BlackBerry Curve 8530 Keypad Replacement: stap 5, afbeelding 2 van 3 BlackBerry Curve 8530 Keypad Replacement: stap 5, afbeelding 3 van 3
      • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
      • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
      Vraag FixBot
      Voeg opmerking toe
    4. BlackBerry Curve 8530 Keypad Replacement: stap 6, afbeelding 1 van 2 BlackBerry Curve 8530 Keypad Replacement: stap 6, afbeelding 2 van 2
      • The keyboard should slide off of the phone now that the plastic siding has been removed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble the device, follow the instructions in reverse order.
4 andere personen hebben deze handleiding voltooid.
Cory Davis
503 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-13, Regan Spring 2011 Lid van Cal Poly, Team 15-13, Regan Spring 2011
CPSU-REGAN-S11S15G13
3 Leden
35 handleidingen geschreven
1Gids Commentaar
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 31
Altijd: 6,837
