Ga door naar hoofdinhoud
BlackBerry 7100g Screen Replacement
Wat je nodig hebt
  1. BlackBerry 7100g Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
    Vraag FixBot
    Voeg opmerking toe
  2. BlackBerry 7100g Screen Replacement: stap 2, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement: stap 2, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement: stap 2, afbeelding 3 van 3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
    Vraag FixBot
    Voeg opmerking toe
  3. BlackBerry 7100g Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the battery housing by flipping up the top of the battery.
    Vraag FixBot
    Voeg opmerking toe
  4. BlackBerry 7100g Screen Replacement, Housing: stap 4, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement, Housing: stap 4, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement, Housing: stap 4, afbeelding 3 van 3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
    Vraag FixBot
    Voeg opmerking toe
  5. BlackBerry 7100g Screen Replacement: stap 5, afbeelding 1 van 2 BlackBerry 7100g Screen Replacement: stap 5, afbeelding 2 van 2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. BlackBerry 7100g Screen Replacement: stap 6, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement: stap 6, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement: stap 6, afbeelding 3 van 3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
    Vraag FixBot
    Voeg opmerking toe
  7. BlackBerry 7100g Screen Replacement: stap 7, afbeelding 1 van 1
    • You can now easily remove the "guts" of the phone from the housing.
    Vraag FixBot
    Voeg opmerking toe
  8. BlackBerry 7100g Screen Replacement, Keypad: stap 8, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement, Keypad: stap 8, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement, Keypad: stap 8, afbeelding 3 van 3
    • Turn the "guts" over so the speaker is facing up.
    • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
    • Separate the battery housing from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. BlackBerry 7100g Screen Replacement: stap 9, afbeelding 1 van 1
    • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
    Vraag FixBot
    Voeg opmerking toe
  10. BlackBerry 7100g Screen Replacement, Screen: stap 10, afbeelding 1 van 2 BlackBerry 7100g Screen Replacement, Screen: stap 10, afbeelding 2 van 2
    • Locate the ribbon connector below the bottom of the screen.
    • Use a spudger to flip up the connector.
    Vraag FixBot
    Voeg opmerking toe
  11. BlackBerry 7100g Screen Replacement: stap 11, afbeelding 1 van 3 BlackBerry 7100g Screen Replacement: stap 11, afbeelding 2 van 3 BlackBerry 7100g Screen Replacement: stap 11, afbeelding 3 van 3
    • Locate the four (4) white tabs that attach the screen to the motherboard.
    • Carefully detach the tabs from the motherboard.
    • The screen can now be removed from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adriel Salinas
42 Reputatie
2 handleidingen geschreven
Cal Poly, Team 25-87, Amido Spring 2010 Lid van Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Leden
33 handleidingen geschreven
1Gids Commentaar
just a heads up don't do this with a iPhone it does not work at All!
Jaxson HUTCHINSON - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 29
Altijd: 2,330
