Ga door naar hoofdinhoud
Black and Decker Pivot MAX Power Switch Replacement
Wat je nodig hebt
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: stap 1, afbeelding 1 van 2 Black and Decker Pivot MAX Power Switch Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Power Switch Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Power Switch Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Power Switch Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Power Switch Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: stap 6, afbeelding 1 van 1
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Power Switch Replacement: stap 7, afbeelding 1 van 1
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: stap 8, afbeelding 1 van 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: stap 8, afbeelding 2 van 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: stap 8, afbeelding 3 van 3
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
  9. Black and Decker Pivot MAX Power Switch Replacement: stap 9, afbeelding 1 van 2 Black and Decker Pivot MAX Power Switch Replacement: stap 9, afbeelding 2 van 2
    • Pull the power switch out softly.
    • Desolder the wires from the old power switch to the new one.
    • Check out our Hoe moet je (de-)solderen? guide if you need any help!
Conclusie
1Gids Commentaar
Where may I buy a power switch?
Joan Williamson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 1,383
