Ga door naar hoofdinhoud
Black and Decker LI2000 Circuit Board Replacement
Wat je nodig hebt
  1. Black and Decker LI2000 Circuit Board Replacement, Orange Casing: stap 1, afbeelding 1 van 3 Black and Decker LI2000 Circuit Board Replacement, Orange Casing: stap 1, afbeelding 2 van 3 Black and Decker LI2000 Circuit Board Replacement, Orange Casing: stap 1, afbeelding 3 van 3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
  5. Black and Decker LI2000 Circuit Board Replacement, Handle: stap 5, afbeelding 1 van 2 Black and Decker LI2000 Circuit Board Replacement, Handle: stap 5, afbeelding 2 van 2
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Circuit Board Replacement: stap 6, afbeelding 1 van 2 Black and Decker LI2000 Circuit Board Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Circuit Board Replacement, Battery: stap 7, afbeelding 1 van 2 Black and Decker LI2000 Circuit Board Replacement, Battery: stap 7, afbeelding 2 van 2
    • Using pliers or your fingers, remove the leads off of the battery.
  8. Black and Decker LI2000 Circuit Board Replacement, Circuit Board: stap 8, afbeelding 1 van 1
    • Refer to the Soldering Technique Guide to remove the wires on the circuit board that connect the charging adapter by applying heat from iron to existing solder on the board.
    • Keep track of which wire connected to which part of the board.
  9. Black and Decker LI2000 Circuit Board Replacement: stap 9, afbeelding 1 van 1
    • Refer to the Soldering Technique Guide to remove the wires from the circuit board that connect to the battery by heating the existing solder on the leads.
    • Keep track of which wire was connected to which part of the circuit board.
Conclusie
Katherine Simmons
732 Reputatie
5 handleidingen geschreven
IUPUI, Team 1-3, Baechle Spring 2016 Lid van IUPUI, Team 1-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 553
