Ga door naar hoofdinhoud
Black and Decker JS660 Trigger Replacement
Wat je nodig hebt
  1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: stap 1, afbeelding 1 van 2 Black and Decker JS660 Trigger Replacement, Housing Disassembly: stap 1, afbeelding 2 van 2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Black and Decker JS660 Trigger Replacement: stap 2, afbeelding 1 van 1
    • By separating the two housing halves, carefully remove the top plate.
    Vraag FixBot
    Voeg opmerking toe
  3. Black and Decker JS660 Trigger Replacement, Power Cord: stap 3, afbeelding 1 van 1
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Black and Decker JS660 Trigger Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
    Vraag FixBot
    Voeg opmerking toe
  5. Black and Decker JS660 Trigger Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the black and white cord from the trigger assembly.
    Vraag FixBot
    Voeg opmerking toe
  6. Black and Decker JS660 Trigger Replacement, Trigger: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to press down on these tabs on the trigger assembly.
    • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
    • Each cord needs to be done separately.
    Vraag FixBot
    Voeg opmerking toe
  7. Black and Decker JS660 Trigger Replacement: stap 7, afbeelding 1 van 1
    • Remove pink wires from trigger assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
matt murray
682 Reputatie
6 handleidingen geschreven
Cal Poly, Team 22-9, Maness Winter 2017 Lid van Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 1,770
