Ga door naar hoofdinhoud
Benchmade Griptillian Disassembly
Wat je nodig hebt
    1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: stap 1, afbeelding 1 van 1
      • Be sure to make note of what side the belt clip is on for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    2. Benchmade Griptillian Disassembly, Remove screws: stap 2, afbeelding 1 van 1
      • Use a T6 bit to remove the two screws holding the belt clip.
      Vraag FixBot
      Voeg opmerking toe
    3. Benchmade Griptillian Disassembly, Remove T6 Screws: stap 3, afbeelding 1 van 1
      • Use the T6 bit to remove the four screws holding the handle in place.
      Vraag FixBot
      Voeg opmerking toe
    4. Benchmade Griptillian Disassembly, Turn the knife over: stap 4, afbeelding 1 van 1
      • Turn the knife over and remove one T6 screw.
      Vraag FixBot
      Voeg opmerking toe
    5. Benchmade Griptillian Disassembly, Remove the T8 screw: stap 5, afbeelding 1 van 1
      • Turn the knife over and remove the T8 screw that is going through the hinge.
      Vraag FixBot
      Voeg opmerking toe
    6. Benchmade Griptillian Disassembly, Remove the handle: stap 6, afbeelding 1 van 1
      • Once you've removed the screw, you can remove the handle.
      Vraag FixBot
      Voeg opmerking toe
    7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: stap 7, afbeelding 1 van 1
      • Using the T6 bit, drive the hinge pin out of the other handle.
      Vraag FixBot
      Voeg opmerking toe
    8. Benchmade Griptillian Disassembly, Remove the other handle: stap 8, afbeelding 1 van 1
      • Once you've done this you can remove the other handle.
      Vraag FixBot
      Voeg opmerking toe
    9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: stap 9, afbeelding 1 van 1
      • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
      Vraag FixBot
      Voeg opmerking toe
    10. Benchmade Griptillian Disassembly, Sand both sides of copper: stap 10, afbeelding 1 van 1
      • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
      Vraag FixBot
      Voeg opmerking toe
    11. Benchmade Griptillian Disassembly, Reverse process to re assemble: stap 11, afbeelding 1 van 1
      • Reverse process to re assemble.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Spin Modder
256 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 70
Altijd: 1,573
