Ga door naar hoofdinhoud
Beats Studio3 Wireless Speaker Replacement
Wat je nodig hebt
  1. Beats Studio3 Wireless Speaker Replacement, Ear Pad: stap 1, afbeelding 1 van 2 Beats Studio3 Wireless Speaker Replacement, Ear Pad: stap 1, afbeelding 2 van 2
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Speaker Replacement: stap 2, afbeelding 1 van 3 Beats Studio3 Wireless Speaker Replacement: stap 2, afbeelding 2 van 3 Beats Studio3 Wireless Speaker Replacement: stap 2, afbeelding 3 van 3
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Speaker Replacement, Speaker: stap 3, afbeelding 1 van 2 Beats Studio3 Wireless Speaker Replacement, Speaker: stap 3, afbeelding 2 van 2
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Speaker Replacement: stap 4, afbeelding 1 van 3 Beats Studio3 Wireless Speaker Replacement: stap 4, afbeelding 2 van 3 Beats Studio3 Wireless Speaker Replacement: stap 4, afbeelding 3 van 3
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Speaker Replacement: stap 5, afbeelding 1 van 3 Beats Studio3 Wireless Speaker Replacement: stap 5, afbeelding 2 van 3 Beats Studio3 Wireless Speaker Replacement: stap 5, afbeelding 3 van 3
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
Conclusie
Nayeli watts
474 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 Lid van UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G4
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 82
Altijd: 854
