Ga door naar hoofdinhoud
Beats Studio First Generation Batteries Replacement
Wat je nodig hebt
    1. Beats Studio First Generation Batteries Replacement, Identify the Left Speaker Housing: stap 1, afbeelding 1 van 1
      • The left speaker is the speaker that holds the batteries and does not have the power switch.
      Vraag FixBot
      Voeg opmerking toe
    2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: stap 2, afbeelding 1 van 3 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: stap 2, afbeelding 2 van 3 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: stap 2, afbeelding 3 van 3
      • Place two fingers on each side of the cap. Press and twist counterclockwise to loosen the cap.
      • Once the cap is loose, simply lift the cap out to reveal the batteries.
      Vraag FixBot
      Voeg opmerking toe
    3. Beats Studio First Generation Batteries Replacement, Batteries!: stap 3, afbeelding 1 van 1
      • Carefully pull the batteries out of their housings. When putting in new batteries, make sure that you place each battery in the correct orientation.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
24 andere personen hebben deze handleiding voltooid.
Oscar
1.216 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-18, Regan Spring 2014 Lid van Cal Poly, Team 9-18, Regan Spring 2014
CPSU-REGAN-S14S9G18
4 Leden
42 handleidingen geschreven
29Gids Commentaar
hi man you post is help me a lot thank you..God bless you
EL TIO SAM MARS - Antwoord Deel
Are u using 4A batteries on this? Please reply ASAP. The 3a batteries won't fit on my beats wireless studio.
Nessa Upzs - Antwoord Deel
They are 2 x AAA batteries. This is Beats Studio first generation which are WIRED headphones.
John Coops - Antwoord Deel
Help,I'm trying to twist off battery compartment and it's not budging! Should I try and pry off w/screwdriver! Any ideas?
Kathy - Antwoord Deel
hello jus curious if u got the cap to come off n how if so? any advice wld b greatly appreciated please n thank u
Randi - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 186
Altijd: 153,870
