Ga door naar hoofdinhoud
Beats Studio 3 Headband Replacement
Wat je nodig hebt
  1. Beats Studio 3 Headband Replacement, Headband: stap 1, afbeelding 1 van 1
    • Slide the headband down to reveal the the screws
    • Unscrew both screws from each side of the Headphones.
    Vraag FixBot
    Voeg opmerking toe
  2. Beats Studio 3 Headband Replacement: stap 2, afbeelding 1 van 3 Beats Studio 3 Headband Replacement: stap 2, afbeelding 2 van 3 Beats Studio 3 Headband Replacement: stap 2, afbeelding 3 van 3
    • Remove the foam pad
    • Remove the cushion pad
    • Remove the broken headband.
    • Keep the cushion pad and foam pad to the side.
    • When removing the cushion pad, you will have to use some force and will make a snapping noise, which is normal.
    Vraag FixBot
    Voeg opmerking toe
  3. Beats Studio 3 Headband Replacement: stap 3, afbeelding 1 van 2 Beats Studio 3 Headband Replacement: stap 3, afbeelding 2 van 2
    • Get the new headband and snap back the cushion pad together.
    • Put back the foam pad together.
    Vraag FixBot
    Voeg opmerking toe
  4. Beats Studio 3 Headband Replacement: stap 4, afbeelding 1 van 2 Beats Studio 3 Headband Replacement: stap 4, afbeelding 2 van 2
    • Screw in both screws on each side of the headphones.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
  1. locate screws and unscrew
  2. remove cushion, foam, and broken headband
  3. remove any broken plastic inside the clasps
  4. get the new headband and place it on the headphones; make sure the letter B is on the left and the S on the right of the headphones
  5. place foam and cushion with the headband. It will make a snapping noise if done correctly
  6. screw in the screws
10 andere personen hebben deze handleiding voltooid.
Ivan
379 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 3-3, Briggs Fall 2023 Lid van CSU Los Angeles, Team 3-3, Briggs Fall 2023
CSULA-BRIGGS-F23S3G3
3 Leden
2 handleidingen geschreven
3Gids Commentaar
I've been doing this regularly, usually it lasts less than a year. Are there any replacement kits that are more durable, or are they all equally flimsy?
Creaky Recoil - Antwoord Deel
Broken headband? This an obvious design flaw but keeps the company in the green. There is way too much stress from the hinges put upon the little plastic tabs which act as screw posts on each end of the headband. In a perfect world the headband would be made of steel or reinforced with wire all the way into the screw posts. Perhaps oiling the spring hinge lock tabs and seats would help alleviate some stresses from folding/unfolding but there is still a lot of force applied to these two little plastic tabs on each side of the headband.
Junk design but a win-win for Apple. Since replacement headbands are in the $20 range (they do come in matching colors) and typically last about 10-12 months or less as previous poster says, Beats are a money magnet. If Dre really uses these he probably wears them for a day or two then tosses them before they could break anyway.
Paul B - Antwoord Deel
I pretty much was moments away from ordering a new pair of headphones when I decided to see if there’s any way to resurrect my headphone. Not only was it easy to repair I’ve saved hundreds of dollars by simply following his step by step instructions which was easy to follow. Thanks again 👍🏾
Derrell Dudley - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 59
Afgelopen 30 dagen: 337
Altijd: 9,780
