Ga door naar hoofdinhoud
Beats Studio 2 Wireless Battery Replacement
Wat je nodig hebt
  1. Beats Studio 2 Wireless Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Beats Studio 2 Wireless Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: stap 2, afbeelding 1 van 2 Beats Studio 2 Wireless Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: stap 5, afbeelding 1 van 3 Beats Studio 2 Wireless Battery Replacement: stap 5, afbeelding 2 van 3 Beats Studio 2 Wireless Battery Replacement: stap 5, afbeelding 3 van 3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
Conclusie
Jack Wilson
494 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Lid van UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 143
Altijd: 1,943
