Inleiding
This guide describes all of the necessary steps to replace the battery in the VENSTAR Taco. This guide is needed when the original device battery no longer holds a charge. Hazards when following this guide are risks associated with soldering the wires from the battery to the motherboard. The tool involved in replacing the battery is a soldering tool.
Wat je nodig hebt
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Gereedschap gebruikt in deze stap:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Gereedschap gebruikt in deze stap:Tweezers$4.99
A black fabric covers the ribbon retaining flap, remove it using the curved tweezers as it can be a fire hazard when soldering.
Using a portable soldering iron, melt the solder on the red and black wires on the logic board. Be careful as you are working with the hot metal, it can burn you!
As an alternative to soldering, you can cut the red and black wires close to the battery and strip the ends. Then crimp the new battery's wires to the old wires on the board, making sure to match red to red and black to black.
Be careful soldering the wires for the new battery onto the logic board as you can burn yourself while doing it. To reassemble your device, follow the instructions from the VENSTAR Taco Disassembly page in reverse order.
